How can I combine results from two branches/runs into a single output in one n8n workflow?
(I have one branch returning 59 items and another returning 9, and I’d like to get a combined total of 68 items in one result.)
Assume the Aggregate node returned a var called data, you could use a code node like this to loop over all the executions and merge them in. In your case it’s probably the Merge 1 node’s output
Yes it should be after merge if you are trying to merge the 2 runs
That Code node returns this error : Code doesn’t return items properly
Please return an array of objects, one for each item you would like to output.
@Rohit_Gurav (unrelated to this post so please everyone else ignore), saw your previous post about Apollo integration which was already closed and curious to hear if you found a solution as I am trying to do the same. If you are keen to share, my email is lukas.leo.roth@gmail.com, would appreciate if you could share if/how you figured out it before I go down that rabbit hole. Thanks mate!
To everyone else, sorry for “abusing” the thread, unfortunately there is no direct chat.
Hi @Shant please can you share your workflow in a code block. A simple screenshot does not give me enough context. The code node should be outside of any loops
