I am running the latest Version of n8n (Gets automatically updated every day at 4 am, so I am sure its the latest stable build.) yet it shows 0 production executions lately. I have tested it and confirmed even though the executions themselves work in production, the statistics are completely broken. I avarage about 200k prod executions so something seems very wrong if the statistics show 0 but all executions still work.
Does anybody know what might be wrong?
n8n Debug Info:
core
- n8nVersion: 2.17.7
- platform: docker (self-hosted)
- nodeJsVersion: 24.14.1
- nodeEnv: production
- database: postgres
- executionMode: regular
- concurrency: -1
- license: enterprise (production)
storage
- success: all
- error: all
- progress: false
- manual: true
- binaryMode: filesystem
pruning
- enabled: true
- maxAge: 1 hours
- maxCount: 10000 executions
client
- userAgent: mozilla/5.0 (windows nt 10.0; win64; x64) applewebkit/537.36 (khtml, like gecko) chrome/147.0.0.0 safari/537.36
- isTouchDevice: false
security
Generated at: 2026-04-25T12:17:09.114Z
Hi @letsmanuel welcome
Your pruning config is extremely aggressive: maxAge = 1 hour with maxCount = 10,000. At ~200k executions per day, pruning is constantly deleting almost everything. The execution statistics/insights panel queries the executions table, so if rows are being wiped within an hour, the dashboard has very little to count.
Can you run a quick count directly against Postgres to see whatās actually in the table?
SELECT status, COUNT(*) FROM execution_entity GROUP BY status;
That will tell us whether the data exists in the DB but the UI isnāt showing it (a bug) vs the data is genuinely being pruned before anything can display it (a config issue).
Since you auto-update daily, do you know roughly when this started? That would help pin it to a specific 2.17.x release.
If the DB query shows rows exist but the UI shows 0, thatās a real bug worth filing on GitHub. If the DB is also near-empty, then your pruning window just needs to be wider.
Let me know
Started about 3 days ago! (Could be a bit longer, but it was working 5 days ago!]
And about the pruning: I was always doing that without any problem, since it seems like the statistics are seperate from the actual table content. (Blatant guess based on what I observed over the last 3 months now.]
Also here is your output:
status | count
running | 2586
success | 4
If you wish, I can share the excact cleanup script that I am using, if that helps!
@letsmanuel that confirms itās a bug, not a config issue. Your executions complete successfully but n8n isnāt flipping their status from running to success in the DB. Thatās why stats show 0, and why you have 2,586 stuck executions (the docs say executions with running status are exempt from pruning, so they just accumulate).
Two things Iād do:
File a GitHub issue with your debug info, the SQL output, and that it started 3-5 days ago after auto-update. The n8n version before and after the break would be extremely helpful if you have any logs or image pull history. This is a clear 2.17.x regression in how execution status is finalized.
Immediate cleanup for the stuck rows, yes please share your cleanup script. In the meantime, this should clear them:
UPDATE execution_entity SET status = āunknownā WHERE status = ārunningā AND āstartedAtā < NOW() - INTERVAL ā2 hoursā;
(Using unknown rather than success since we donāt actually know if they all succeeded. Adjust the interval to whatever makes sense for your longest-running workflow.)
Also, consider pinning your docker image to the version that was working before as a temporary fix.
pgq_check "DELETE execution_data" "DELETE FROM execution_data;"
pgq_check "DELETE execution_entity" "DELETE FROM execution_entity;"
pgq_soft "VACUUM FULL execution_data" "VACUUM FULL execution_data;"
if [ $? -ne 0 ]; then
pgq_soft "VACUUM ANALYZE execution_data" "VACUUM ANALYZE execution_data;"
fi
pgq_soft "VACUUM FULL execution_entity" "VACUUM FULL execution_entity;"
pgq_soft "VACUUM ANALYZE execution_entity" "VACUUM ANALYZE execution_entity;"
fi
pgq_soft "ANALYZE execution_data" "ANALYZE execution_data;"
pgq_soft "ANALYZE execution_entity" "ANALYZE execution_entity;"
Thanks for the reply. Above is the important part of the cleanup (Note: This does purge everything, but as stated worked previously) script. Before opening a bug report I thought iād share it incase something is somehow suddenly wrong with it.
This script runs using a cronjob:
0 2 * * * cd /root/n8n_data && /bin/bash db_cleanup.sh >> /root/n8n_data/db_cleanup.log 2>&1
If nothing seems very wrong with the script however, I will open a bug report ofcourse!
I had the same issue after the recent update.
With pruning set to only 1 hour, the execution data gets deleted before the statistics can calculate and show the numbers. Thatās why it displays 0 even though everything is actually running.
Try increasing the maxAge to at least 24 hours and see if the stats come back. That fixed it for me.
