Hey everyone,
Over the last few weeks I’ve built three finance automation workflows in n8n, all using easybits Extractor as the AI backbone for document extraction and classification. The workflows cover multi-currency expense tracking, document classification, and invoice approval with confidence scoring.
I wanted to share the top 5 things I learned along the way – things I wish someone had told me before I started.
1. If building the automation takes as long as doing the task once manually, it’s a no-brainer
This was my biggest mindset shift. When I built “Cassi” – a Telegram bot that converts receipt photos into EUR line items in a Google Sheet – the whole thing took about 45 minutes to wire up. That’s roughly how long I used to spend at the end of each month Googling exchange rates and typing crumpled receipts into a spreadsheet. So from month two onwards, I’m only saving time. If your workflow passes that test, people will immediately get it. If it doesn’t, it’s probably too complex to share as a template.
2. The prompt is the entire workflow – treat it like code
This hit me hard when building the document classification workflow. The easybits Extractor pipeline does the heavy lifting, but the quality of what comes back depends entirely on how specific your field definitions and classification prompts are. Vague category descriptions give you vague results. When I wrote detailed decision rules for each document class (medical invoice, hotel invoice, restaurant invoice, etc.) and told the model to return exactly one label or null if uncertain, accuracy jumped significantly. If you’re building any extraction or classification workflow, spend 80% of your time on the prompt and 20% on the nodes.
3. Don’t trust AI extraction blindly – build in a confidence threshold
In the invoice approval pipeline, I used per-field confidence scores (0.0 to 1.0) on every extracted value. A code node splits items at a 0.75 threshold: anything above goes straight through, anything below gets flagged for human review with the exact fields that need checking. The key insight is that AI extraction is not binary – it’s not “works” or “doesn’t work.” It’s a spectrum, and your workflow should reflect that. The best part: over time, tracking which fields get flagged most often (delivery dates, handwritten references, multi-language headers) shows you exactly where the extraction struggles, which builds trust with your team instead of making the whole thing feel like a black box.
4. Start with the simplest possible version – add complexity only when someone asks for it
My first version of the document classification workflow had Google Drive routing, Slack alerts for low-confidence results, and confidence scoring built in. I ended up stripping all of that out for the published template. The core is just: upload a document → easybits classifies it → you get back a label. That’s it. Anyone can import that and get value in 10 minutes. The Drive routing, the Slack alerts, the approval logic — those are things people add downstream when they need them. If you’re building a workflow to share, ship the skeleton, not the mansion.
5. Use tools people already have as your UI
For the receipt tracker, I used Telegram as the interface. No custom frontend, no web form, no app to install. People already have Telegram on their phone. The entire interaction is: take a photo, send it to a bot, done. The Google Sheet on the other end is the same — your finance colleague doesn’t need to learn a new tool, they just open the spreadsheet they already use. When I later built the document classification workflow, I used n8n’s built-in web form for the upload. Still zero custom frontend. The lesson: the less your users have to change their behavior, the faster they’ll actually adopt the thing you built.
The Three Workflows
Here’s a quick overview of what I built, in case any of these are useful to you:
Workflow 1 – Receipt-to-Sheet (Multi-Currency Expense Tracker) Telegram photo → easybits Extractor (pulls invoice number, currency, amount) → Currency API (live exchange rate with fallback) → Code node (conversion math) → Google Sheets. Built in ~45 minutes. I haven’t brought a physical receipt back to the office since. → Grab the workflow template here
Workflow 2 – Document Classification n8n web form upload (PDF, PNG, JPEG) → base64 conversion → easybits Extractor (classifies into your defined categories) → returns the document class. Clean, minimal, extensible. You define the categories in your easybits pipeline and the workflow just works.
Workflow 3 – Invoice Approval Pipeline Gmail trigger → filter for attachments → AI extracts every line item with per-field confidence scores → code node splits at confidence threshold → high-confidence items auto-logged, low-confidence items flagged → Slack approval buttons (approve / reject / flag) → routes to the right Google Sheets tab. Includes a weekly Monday dashboard that posts processing stats and most-flagged-fields to your finance channel.
Bonus – Duplicate Invoice Detector While building these, I also put together a workflow that catches duplicate invoice PDFs coming through Gmail before they hit your books. It extracts invoice data with easybits, checks it against your existing Google Sheet entries, and flags matches. → Grab the workflow template here
All of these are built with n8n + easybits Extractor. The two linked above are ready to import – for the others, drop a comment or DM me and I’ll send the JSON over.
What’s your experience automating finance workflows? Curious if anyone else has hit similar learnings or found different approaches that worked better.
Best,
Felix
