Unlock Automation with n8n: From AI Image Generation to Cloud Storage ![]()
In this hands-on tutorial, you’ll learn how to create a complete automation pipeline using n8n—perfect for those interested in AI and cloud integration.
Together, we’ll build a workflow that:
Generates AI-powered images using OpenAI’s DALL·E 2
Processes the images within n8n, no extra code needed
Uploads the final images directly to your AWS S3 bucket
By the end of the lesson, you’ll have a reusable, no-code workflow that turns simple text prompts into cloud-hosted images—ideal for content creators, developers, and automation enthusiasts.
What You’ll Learn:
How to set up and configure the OpenAI (DALL·E 2) node in n8n
How to process image data efficiently within your workflow
How to connect and upload files to AWS S3 with ease
How to build a robust, reusable automation pipeline combining AI and Cloud Storage
Free workflow template: Store AI-Generated Images in AWS S3: OpenAI Image Creation & Cloud Storage | n8n workflow template
This tutorial is designed to be beginner-friendly, with step-by-step guidance, no scripting required. Let’s automate together!
