# A Problem at Text Courses\> Level Two \>Processing different data types\>Binary Exercise 2
**URL:** <https://community.n8n.io/t/a-problem-at-text-courses-level-two-processing-different-data-types-binary-exercise-2/152228>\
**Category:** Questions\
**Tags:** data-transformation\
**Created:** [July 19, 2025, 3:01am UTC](https://community.n8n.io/t/a-problem-at-text-courses-level-two-processing-different-data-types-binary-exercise-2/152228 "2025-07-19T03:01:54Z")\
**Posts on this page:** 6\
**Page:** 1
<div class="post-metadata">
**Author:** ![edenseeker](https://dub1.discourse-cdn.com/n8n/user_avatar/community.n8n.io/edenseeker/32/95609_2.png) [@edenseeker](https://community.n8n.io/u/edenseeker)\
**Post date:** [July 19, 2025, 3:01am UTC](https://community.n8n.io/t/a-problem-at-text-courses-level-two-processing-different-data-types-binary-exercise-2/152228/1 "2025-07-19T03:01:54Z")
</div>
## Describe the problem/error/question
When I practice this part and execute the node of **Read/Write Files From Disk node** , it will show " The file “/tmp/poetrydb.json” is not writable." Could anyone can tell me how to find and write correct **File Path and Name**?
 ![image](https://europe1.discourse-cdn.com/n8n/original/3X/b/4/b47cadeb73df511d9a40921d9f5075689f221978.png)
## What is the error message (if any)?
Above Picture
## Please share your workflow
 ![image](https://europe1.discourse-cdn.com/n8n/original/3X/9/9/997b6ccb48d4586ad70a681d73b6b3a48d69fbf2.png)
## Share the output returned by the last node
 ![image](https://europe1.discourse-cdn.com/n8n/original/3X/b/6/b6c05f17b60af606df02fb4295a3c539c80336c0.jpeg)
- **n8n version:** 1.102.3
- **Database (default: SQLite):** default
- **n8n EXECUTIONS\_PROCESS setting (default: own, main):** default
- **Running n8n via (Docker, npm, n8n cloud, desktop app):** n8n cloud
- **Operating system:** macOS
**Author:** ![jabbson](https://dub1.discourse-cdn.com/n8n/user_avatar/community.n8n.io/jabbson/32/87328_2.png) [@jabbson](https://community.n8n.io/u/jabbson)\
**Post date:** [July 19, 2025, 3:27am UTC](https://community.n8n.io/t/a-problem-at-text-courses-level-two-processing-different-data-types-binary-exercise-2/152228/2 "2025-07-19T03:27:25Z")
</div>
Hey @edenseeker hope all is well.
In the post it says you are running the cloud version of n8n, but I thought the cloud version [didn’t have the Read/Write node](https://docs.n8n.io/integrations/builtin/core-nodes/n8n-nodes-base.readwritefile/#:~:text=This%20node%20isn%27t%20available%20on%20n8n%20Cloud.)? Could you clarify?
**Author:** ![moosa](https://dub1.discourse-cdn.com/n8n/user_avatar/community.n8n.io/moosa/32/108437_2.png) [@moosa](https://community.n8n.io/u/moosa)\
**Post date:** [July 19, 2025, 3:28am UTC](https://community.n8n.io/t/a-problem-at-text-courses-level-two-processing-different-data-types-binary-exercise-2/152228/3 "2025-07-19T03:28:46Z")
</div>
you can refer to this question.
it seems to address your issue:
> [@Binary Exersie 2 - System Error?](http://community.n8n.io/t/binary-exersie-2-system-error/102241):
> Hello, I’ve been stuck on the Level Two course exercise ‘Binary Exercise 2’. I’ve followed the exercise guideliens closely and even copied the node from the solution, yet I cannot save the JSON file to the /tmp/ directory. It consistantly says that the file is not writeable. Please see the image below: Please share your workflow ##Here is the relevant node: { “parameters”: { “operation”: “write”, “fileName”: “/tmp/poetrydb.json”, “options”: {} }, “id”: “f2048e5d-fa8f…
**Post date:** [July 19, 2025, 3:47am UTC](https://community.n8n.io/t/a-problem-at-text-courses-level-two-processing-different-data-types-binary-exercise-2/152228/4 "2025-07-19T03:47:19Z")
</div>
Hi @jabbson，thanks for your solution.
This workflow does work successfully when I run it in local n8n.
**Post date:** [July 19, 2025, 9:14am UTC](https://community.n8n.io/t/a-problem-at-text-courses-level-two-processing-different-data-types-binary-exercise-2/152228/5 "2025-07-19T09:14:07Z")
</div>
Thanks for your share @moosa. This is exactly the same issue that I encounter.
With your and @jabbson’s help, I found when using n8n cloud version, the file path and name should be “/home/node/.n8n/poetry.json”, but in the n8n local version, it should be “/tmp/poetrydb.json”.
Do you know what causes this differences?
**Author:** ![system](https://dub1.discourse-cdn.com/n8n/user_avatar/community.n8n.io/system/32/195824_2.png) [@system](https://community.n8n.io/u/system)\
**Post date:** [July 26, 2025, 9:14am UTC](https://community.n8n.io/t/a-problem-at-text-courses-level-two-processing-different-data-types-binary-exercise-2/152228/6 "2025-07-26T09:14:13Z")
</div>
Closed on July 26, 2025, 9:14am UTC
