# A Problem With Error Workflow/Node
**URL:** <https://community.n8n.io/t/a-problem-with-error-workflow-node/164326>\
**Category:** Questions\
**Tags:** error-trigger\
**Created:** [August 8, 2025, 8:41am UTC](https://community.n8n.io/t/a-problem-with-error-workflow-node/164326 "2025-08-08T08:41:03Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![yurtgoktug](https://dub1.discourse-cdn.com/n8n/user_avatar/community.n8n.io/yurtgoktug/32/71827_2.png) [@yurtgoktug](https://community.n8n.io/u/yurtgoktug)\
**Post date:** [August 8, 2025, 8:41am UTC](https://community.n8n.io/t/a-problem-with-error-workflow-node/164326/1 "2025-08-08T08:41:03Z")
</div>
## Describe the problem/error/question
```auto
Hello everyone,
I'm writing to see if anyone has experienced an issue similar to what I've encountered with one of my workflows. The problem started on August 1st, and I'm unsure if it's a bug with n8n or an issue with my workflow's configuration.
My workflow is linked to an Error Workflow designed to instantly report problems. However, a specific HTTP Request node in another workflow has been consistently failing since August 1st. The unexpected behavior is that the Error Workflow was not sending me email notifications for these failures. To make things more confusing, it's reporting these errors as both successful and failed 144 executions both failed and successful). I only became aware of this today because I haven't received any error emails.
I've attached a screenshot for reference. Is anyone else seeing this kind of issue with the Error node/workflow?
Thank you for your assistance.
 ![Screenshot 2025-08-08 at 10.51.47](https://europe1.discourse-cdn.com/n8n/original/3X/f/9/f94bc06d86ce4c58139bc5bd98c98a4f92994fe4.png)
```auto
 ![Screenshot 2025-08-08 at 10.51.53](https://europe1.discourse-cdn.com/n8n/original/3X/a/3/a3ccb061a4e9ab3c10f359a4547c805658775356.png)
```auto
## Share the output returned by the last node
- **n8n version: 1.105.3**
- **Database (default: SQLite):**
- **n8n EXECUTIONS\_PROCESS setting (default: own, main):**
- **Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud**
- **Operating system: mac**
**Author:** ![fahmiiireza](https://dub1.discourse-cdn.com/n8n/user_avatar/community.n8n.io/fahmiiireza/32/111833_2.png) [@fahmiiireza](https://community.n8n.io/u/fahmiiireza)\
**Post date:** [August 10, 2025, 12:44pm UTC](https://community.n8n.io/t/a-problem-with-error-workflow-node/164326/2 "2025-08-10T12:44:57Z")
</div>
Hi there, if you can to share the workflow/the execution where this http request are failing? does it always fail because of the same issue? whats the error body and header? does the workflow stops when the http is in error?
this information will definitely help us to help you better!
