Quick thought for the n8n community:
A workflow is not production-ready just because the happy path works.
If there is no logging, alerting, retry logic, error handling, or clear way to trace what happened when something fails, then it is still closer to a prototype than a dependable business process.
The real test is not, “Did it run once?”
The real test is, “What happens when the API times out, the data is incomplete, the AI response is messy, the rate limit hits, or the client needs to know exactly where things broke?”
That is where n8n builders can separate themselves.
Not just by building workflows that work when everything goes right, but by designing systems that still make sense when things go wrong.
