I’m having issues making the AMQP nodes work with ActiveMQ on AWS. The trigger node is not able to resolve messages in ActiveMQ. I have a local installation which currently runs on docker. I got this error message from docker logs.
[connection-1] error on read: ProtocolError: Invalid protocol header for AMQP §♥♥ (buffer:0x15,0x03,0x03,0x00,0x02,0x02,0x0a,0x15,0x03,0x03,0x00,0x02,0x02,0x0a)
the error shows n8n is getting TLS/SSL data back when it expects the AMQP protocol - AWS ActiveMQ uses port 5671 for AMQPS but you might need to check if they require a specific protocol version or if your broker is configured for AMQP 1.0 (n8n uses 0.9.1 by default).
try switching the port to 61617 which is ActiveMQ’s OpenWire+SSL port, or if you need AMQP specifically, make sure your AWS broker has AMQP enabled and youre using the right endpoint - AWS sometimes has different URLs for different protocols. also double check the Transport Type - if the port expects SSL/TLS to be negotiated differently you might need to adjust that setting.
lmk if switching ports helps or if you need the specific AWS ActiveMQ endpoint config
