The idea is:
Make Rename keys more powerful
My use case:
I would like to rename all object keys using an option or an expression so that I can operate on objects with an arbitrary amount of keys and key names -
this is very useful for use with the merge by key functionality as sometimes two data streams will have very similar keys
Potentially, I may end up writing some code to do this myself and will post here if I end up doing that (seems pretty simple to achieve)
