The idea is:
Create an abort node with saving execution options. It would be nice to have a third option for “saving” the executions. Such as another option “Save executions when ABORT_NODE is called” with the usual save/don’t save/default.
My use case:
I have a workflow where I want to save both failed and successful executions, but I don’t want to save an execution where nothing useful happened. My workflow is a timer trigger every couple minutes - then list files in a folder - IF any file exists, true = continue to main workflow, if false, stop there.
Failed executions help diagnose where the blindspots are in a workflow, but also successful ones, if a workflow was successful, but with unexpected values as the output. This could also be used as “Save only when node is called”
I don’t think I’m quite qualified to “work” on this, but hey. Why not.
