Add concurrency in workflow settings
Wild that this is not implemented. Will it be a part of version 2?
+1 waiting for this
Any updats?
Can’t believe this is not there yet :laughing:
Another vote. I have tools that can send multiple alerts simultaneously for essentially the same thing, from which I process and create a ticket if necessary. But I need to check if there’s an open ticket already so I don’t create multiple tickets. When I was doing this in power automate it was easy enough to set the flow concurrency to 1.
For @flowdan’s dedup use case, a workable pattern until this is native: use static workflow data as a mutex at the start of the run. Set $getWorkflowStaticData('global').processing = true in a Code node at the top, add an IF node that exits early if the flag is already true, then clear the flag at the end (and in your error handler). It handles single-concurrency cases without queue mode. Not pretty, but it keeps multiple simultaneous triggers from stomping on each other.
Well, my situation is a bit more complex. Most are realtime, but certain alerts are batched and come in every hour. While I may get multiple alerts for the same thing at times, other unrelated alerts can also come through. The runs would still need to queue to ensure nothing is missed.
