Just wondering how to install and enable an npm module for an instance setup using the docker-compose example?
I can see that there is an environment variable to enable the use of modules, but actually getting them installed is the missing link
Im assuming I need to create a docker file, with npm install commands added, and then turn that into an image to use in my docker-compose? Im assuming similar steps to add python?
