Hi
i want to create issue by using n8n
i have configured correctly the workflow and i have succesfull created issue in my project A
but in my project B i have a affects versions is required when you create issue i don’t find affects version in the fields
i don’t find affects versions, have you idea for i can to set a value in affects versions field it’s possible ?
Thanks in advance
