Hi everyone,
I’m trying to build a pipeline in n8n to extract structured business information from an audio call recording using an AI Agent.
Goal
Given an Audio URL, I want an AI agent to analyze the conversation and extract a fixed set of predefined data points into a strict JSON schema.
What I’ve tried so far
HTTP Request node
Used to download the audio file from the URL
Response format set to File
Binary data is generated correctly (I can play/download the audio from the Binary tab)
AI Agent node
Configured to use Gemini 3 Flash Preview via an LLM proxy (LiteLLM)
Passed:
A detailed system prompt
A detailed user prompt
A strict output JSON schema
Enabled “Automatically parse binary files”
Tried passing:
Only the Audio URL
Only the audio binary
Both the Audio URL and binary together
Transcription nodes
I have already tried:
Gemini Transcribe node
OpenAI Transcribe node
These are not suitable for my use case because:
I do not just need a transcript
I need specific structured data points extracted directly from the call
The Gemini Transcribe node requires Google PaLM API credentials, while I am accessing Gemini models only through a LiteLLM proxy, not directly via Google APIs
What’s going wrong
The AI Agent:
Either returns empty JSON
Or returns random / hallucinated values
The behavior suggests that:
The audio is not actually being processed
Or the model is ignoring the audio input entirely
This happens even though:
The audio binary exists and is valid
MIME types are correct (e.g.
audio/mpeg) -
Gemini 3 Flash Preview claims to support audio inputs
What I suspect
One or more of the following may be true:
The AI Agent node does not truly support audio input, even when binary parsing is enabled
Gemini audio support may require direct Gemini API calls rather than an AI Agent abstraction
What I’m looking for help with
Has anyone successfully used:
AI Agent with audio input?
Gemini via LiteLLM for multimodal audio processing?
Is audio → AI Agent currently unsupported in n8n?
Is STT → extraction the recommended approach?
If single-step audio analysis is possible, what is the correct node / configuration?
Any confirmation, working examples, or architectural guidance would be greatly appreciated.
Thanks in advance!
