Hi,
Need:
Output the highest possible quality from AI.
Objective: A workflow with two AIs debatting until a final solution is found.
Example of use case
- User inputs some code
- AI #1 audits it
- AI #2 audit it
=> Until both Audits are not aligned, the two AIs keep ‘discussing’.
Question
Do you know if we can do this?
Ideas of nodes to use:
. Orchestrator AI Agent
. Two AI tools doing the Audit alternatively
. A loop
Thanks in advance.
- **n8n version:**Last
- **Database (default: SQLite):**default
- **n8n EXECUTIONS_PROCESS setting (default: own, main):**self hostef
- **Operating system:**Windows
