Hello, I want to record data on airtable . However, it records 17 times from the same data and adds data in the form of 17X5 in total. What is the cause of this problem or what is the solution?
Hi @mustafa_isik, welcome to the community! I am sorry to hear you’re having trouble.
Can you share a workflow using which the problem can be reproduced and also confirm the JSON data you’re passing on to your Airtable node?
