The idea is:
Bypass node input to output
This PR adds a new “Bypass previous node output” feature that allows nodes to automatically include specified fields from previous node outputs in their own outputs. This enables preserving important data throughout a workflow without requiring manual configuration at each step.
The feature works by adding a text field in node settings where users can provide a comma-separated list of field names to be preserved. These fields are then automatically copied from the previous node’s output to the current node’s output, ensuring data continuity across the workflow.
Implementation details
- Added byPass property to node interfaces
- Implemented bypass field processing in the workflow execution engine
- Added UI settings field for configuring bypass fields
- Supports dot notation for nested properties (e.g., “user.name”)
- Works with all executable nodes in workflows
Testing
The feature can be tested by:
- Adding fields in a node (as shown in the screenshot)
- Setting up subsequent nodes with bypass fields listed
- Running the workflow and confirming that specified fields persist through the node chain
My use case:
When you need global variable to be preserved cross wokflow
When using ai agent or other almost all node, we need to preserve global variable sometimes.
To do this, we need to use merge node but it makes my workflow ugly.
So, I implemented “Bypass” functionality at “Settings”
