The idea is:
To use variables from other places inside a note, so it auto updates. For example one of th fields of that node itself.
My use case:
I have a series of todoist nodes, that create one task each. and I want to easily show within the flow view what each nodes ‘content’ field says. Without having to copy paste it to the notes section every time
Yeah - I’d like to possibly add the ‘last update date’ that you can see when looking at the JSON source of the workflow
"createdAt": "2023-03-09T09:22:59.482Z",
"updatedAt": "2023-03-15T11:43:23.000Z",
"versionId": "91d2b760-9fb0-4af8-9ba4-90c4d6ea317b",
Version ID is a bit chaotic but it’s something.
