Am having trouble using Amazon Bedrock Chat model on AI Agent Tool option when am using the Automatically Passthrough Binary Images, On Older versions of n8n (1.58.2) I could do so but now I cant
A conversation must alternate between user and assistant roles. Make sure the conversation alternates between user and assistant roles and try again.
This looks to be a bug coming from a previous issue fix. I have raised this internally and we’ll get back to you once we have a better understanding.
Thanks for bringing it up!
Just wanted to give you a short update. This issue will likely take a little bit to get fixed, unfortunately.
If you are able to, we’d suggest using another type of model for now, like anthropic or openai. If you’d be up for it, moving to azure or another platform we support would also be a good idea.
I’m sorry for the trouble this makes for you!
We’ll still try to get to it as fast as possible, but we don’t want to leave you hanging until then
Unfortunately not. It could be a while until we manage to get to this. We’re not able to put forward an intended deadline.
I know that’s not what you’d want to hear, but based on the issue prioritisation we must make, this fix is not going to be a quick one. We’re still keeping it in check and trying to get to it asap, but it’s not on the immediate roadmap.
