Am I doing something wrong with Auto-fixing Output Parser
When I have an agent node that needs an structured output, sometimes the LLM will give it to me in a code bubble or the format would not be perfect, for that I thought we had the “Auto-fixing Output Parser” but I never see the model part of it activating, and I think in cases like this it should definetly do
As you can see it moves from having a code bubble with the json to empty answer…
json definition is:
strong text{“type”: “object”,
“properties”: {
“comunication_update”: {
“type”: “string”,
“description”: “Details of the communication update”
“id”: {
“type”: “integer”,
“description”: “Unique identifier for the record”
“Status”: {
“type”: “string”,
“description”: “Current status of the record”
“Stage”: {
“type”: “string”,
“description”: “Current stage of the process”
“required”: [“comunication_update”, “id”, “Status”, “Stage”]
How is it that it doesn’t work? is this a bug?
  "nodes": [
      "parameters": {
        "options": {}
      "id": "f8855e94-f6c2-47bf-a8c9-965b21c6e110",
      "name": "Auto-fixing Output Parser",
      "type": "@n8n/n8n-nodes-langchain.outputParserAutofixing",
      "typeVersion": 1,
      "position": [
        1960,
        720
      "parameters": {
        "options": {}
      "id": "bb01fc25-9993-4a01-8e4e-fcf8a5dae554",
      "name": "OpenAI Chat Model1",
      "type": "@n8n/n8n-nodes-langchain.lmChatOpenAi",
      "typeVersion": 1,
      "position": [
        1920,
        920
      "credentials": {
        "openAiApi": {
          "id": "yv064MBJLbwsL817",
          "name": "OpenAi fix output parser"
      "parameters": {
        "schemaType": "manual",
        "inputSchema": "{\"type\": \"object\",\n  \"properties\": {\n    \"comunication_update\": {\n      \"type\": \"string\",\n      \"description\": \"Details of the communication update\"\n    },\n    \"id\": {\n      \"type\": \"integer\",\n      \"description\": \"Unique identifier for the record\"\n    },\n    \"Status\": {\n      \"type\": \"string\",\n      \"description\": \"Current status of the record\"\n    },\n    \"Stage\": {\n      \"type\": \"string\",\n      \"description\": \"Current stage of the process\"\n    }\n  },\n  \"required\": [\"comunication_update\", \"id\", \"Status\", \"Stage\"]\n}"
      "id": "5cb740bb-9bcc-4b9d-934d-b448b98f5f62",
      "name": "Structured Output Parser",
      "type": "@n8n/n8n-nodes-langchain.outputParserStructured",
      "typeVersion": 1.2,
      "position": [
        2080,
        920
  "connections": {
    "Auto-fixing Output Parser": {
      "ai_outputParser": [
    "OpenAI Chat Model1": {
      "ai_languageModel": [
            "node": "Auto-fixing Output Parser",
            "type": "ai_languageModel",
            "index": 0
    "Structured Output Parser": {
            "type": "ai_outputParser",
            "index": 0
  "pinData": {},
  "meta": {
    "instanceId": "5aa5d2a1603df28859474f270c5663bf0de5fdf9d6c795d12d01619750c46ce4"
## Share the output returned by the last node
<!-- If you need help with data transformations, please also share your expected output. -->
- **n8n version:** 1.76.3
- **Database (default: SQLite):**  Postgres
- **n8n EXECUTIONS_PROCESS setting (default: own, main):**queue
- **Running n8n via (Docker, npm, n8n cloud, desktop app):** online deployed through Docker
- **Operating system:**: windows
same problem here, this node doesn’t fix anything, bad output is propagated further
Also having the exact same issue with this node, can anyone help with this one?
I’m having this exact issue. This makes my ‘respond to webhook’ node return an empty ‘outpt’ object.
Same issue also. I thought maybe it was my configuration, but have spent hours trying to get the Auto-Fixing Output parser to rerun after it gets an error and it doesn’t ever rerun.
Same here, bumping this topic.
