AMQP Triggers and Senders Not Working With AWS MQ
Hello all,
I could easily connect using AMQP node to an Active MQ instance locally. For production setup, I created an Active MQ instance in the AWS cloud which allows both AMQP 1.0 and MQTT.
These protocols on AWS is amqp+ssl://xxxxx and also mqtt+ssl://. However, n8n is unable to connect to it even after making the entire inbound and outbound port for the instance open. It appears there’s an issue with n8n making a secured AMQP and MQTT connection.
Any help around this would be appreciated.
@oyinig welcome to the community.
Thanks for letting us know. Will have a look when I have time.
