Any advice on how to connect Oncehub
I’m looking to connect Oncehub with n8n. I can’t find any built in connectors/credential options and I’m trying to use a webhook. Before I sent a bunch of details I”m hoping someone might have a simple answer.
Hello, I hope this helps. I took a quick look at the Oncehub documentation, and I think the method is quite similar to Stripe. So I made a few adjustments, and I hope this helps you move forward if there are still some inconsistencies.
