I think I have the credentials working since my credential appears to have connected. However, I’ve tried to get my post to work but hit the following error.
I’m reposting since I don’t think I did the past of the node correctly.
NodeApiError: The service was not able to process your request at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/HttpRequest/V3/HttpRequestV3.node.js:1620:35) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:728:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:664:53 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1073:20
- n8n version: 1.42.1
- Database (default: SQLite):
- Operating system: Synology
