API problem with Huggingface (Solved)
Hello Community, (Solved)
My first post here but im a silent reader for long.
My problem right now is that i wanna use a Hugging Face Model which i choose because of the specific language training and other small points which are not relevant at this point.
My Problem right now, the API Key doesn’t work. Are there any solutions to use this modell?
Link to the modell:
https://huggingface.co/primeline/whisper-large-v3-turbo-german
Thank you for your knowledge.
Well without seeing the error I wouldn’t really know, maybe this can help: Hugging Face credentials | n8n Docs
You cannot use this model:
“This model is not currently available via any of the supported Inference Providers”
This model is for local use, maybe try to search “cloudflare ai workers” or look for some ollama free hosting.
For now is not possible to use whisper on huggingface for TTS
Thank you for this lightbulb and i thought its a problem on my side.
