Hi!
I want to parse a broken text that is in Persian/ Arabic. How can I fix this? I mean I need a code to do so.
The out put is this:
But it must be like this: <suggestion data= خرید بیت کوین/>
N8N version: 1.59.4
It’s on Docker
Hi!
N8N version: 1.59.4
It’s on Docker
Thanks for posting! I’m not seeing the actual input in the post, could you describe what’s broken about it and in which node or which part of your workflow you want to parse the text?
