Hi everyone,
I’m exploring how to use n8n as an orchestration layer to integrate two large enterprise systems (for example, SAP and Oracle Finance), ideally without requiring modifications inside either system.
I understand that n8n provides thousands of workflow templates, but most seem focused on smaller integrations (APIs, CRMs, databases, etc.), and I couldn’t find clear examples of enterprise-to-enterprise (ERP-like) integrations.
What I’m specifically looking for:
Any ready-to-use templates or workflows that connect two complex systems (even if they are not SAP/Oracle specifically)
Real examples of system A → transformation → system B patterns
n8n can handle this kind of enterprise orchestration, but don’t expect a plug-and-play “SAP → Oracle Finance” template; they don’t exist out of the box, as far as I know.
For ERP-to-ERP work, you’re basically always building something custom. The pattern looks like this:
Extract or trigger from System A
Normalize the data
Validate required fields
Map/transform fields
Push to System B
Log and audit
Handle retries and errors
n8n is great for that orchestration layer — especially when your systems expose REST, SOAP, OData, database access, SFTP, or webhooks.
For Oracle, there’s a built-in Oracle Database node. For SAP, you’ll likely be working through HTTP/OData/Service Layer patterns or a community connector depending on which SAP product you’re dealing with — check the n8n community nodes for what’s available.
