Thanks for posting here and welcome to the community!
Could you please share more about why it is not working? Are you getting any errors? Are you running the entire workflow (Test Workflow button at the bottom of the canvas) or running it node by node?
Please also share your workflow for full context.
Thanks!
Tip for sharing your workflow in the forum
Pasting your n8n workflow
<your workflow>
Make sure that you’ve removed any sensitive information from your workflow and include dummy data or pinned data as much as you can!
