Auto-Retry execution with error
We have over 1000 runs to run, doing this manually would be a lot of work.
I was looking for a way to do this via API
I found a workflow that does this through the undocumented API, but I couldn’t log in (as these are old posts I don’t know if anything has changed)
If anyone has a way to make this work, I’d appreciate your attention.
https://n8n.io/workflows/3144-auto-retry-engine-error-recovery-workflow/https://community.n8n.io/t/credential-unauthorized/12229/2
Hi @Rodrigo_Barbosa
There is already an endpoint retry that you can use
