Auto-sync and Qualify HubSpot CRM Contacts
Hi Everyone :waving_hand:
This play automates the heavy lifting of lead qualification. Every six hours, the workflow scans your HubSpot CRM for contacts that lack firmographic data or require a refresh. It pulls these contacts into a single Lusha bulk enrichment call, retrieves verified professional data, and then runs them through a custom scoring engine.
Instead of reps manually researching every new sign-up, the system instantly identifies which leads match your ideal customer profile (ICP). High-scoring “fast-track” leads are immediately flagged to the sales team, ensuring your best prospects never sit idle in the database.
I detailed how you can build this out below but If you need more information, you can use the Full Workflow Documentation or other Lusha x n8n workflows here.
Why this works
Speed-to-lead is irrelevant if the lead isn’t qualified. Most teams struggle with either slow manual research or a spray and pray approach to follow-ups.
This play operationalizes efficiency by:
  • Batch processing for speed: Using bulk enrichment to update hundreds of records in seconds.
  • Standardizing qualification: Applying the same ICP logic to every contact automatically.
  • Prioritizing high-value signals: Identifying senior decision-makers at target-sized companies instantly.
  • Reducing CRM noise: Keeping records clean and enriched without manual data entry.
What you get
  • Automated 6-hour sync between HubSpot and Lusha
  • Bulk-enriched firmographic and contact data (industry, size, seniority)
  • Automated ICP scoring based on custom business logic
  • Real-time Slack alerts for “Fast-Track” qualified leads
  • Clean, reliable data for better segmentation and reporting
How to set it up
01 Install the Lusha community node
Ensure your n8n instance is equipped with the Lusha node to handle the high-efficiency bulk enrichment requests.
02 Connect your apps
Securely add your credentials in n8n for:
  • Lusha: API access for contact and company enrichment
  • HubSpot: Permissions to filter, read, and update contact properties
  • Slack: Access to post lead alerts into your sales channels
03 Define your qualification “fast-track”
Customize the ICP scoring weights within the n8n Code node.
Tip: Assign higher values to specific job titles (e.g., VP, Director) and target company sizes (e.g., 500-2000 employees) to trigger the Slack alerts.
04 Configure the HubSpot fetch filter
Set the workflow to pull contacts where “Lusha Enrichment Status” is empty or where specific firmographic fields are missing. This ensures you only spend credits on the data you need.
05 Set up the Slack alert loop
Map the output for high-scoring leads to a dedicated Slack channel. Include key context like the contact’s LinkedIn URL, enriched phone number, and their calculated ICP score so reps can act immediately.
06 Activate the 6-hour trigger
Turn on the workflow. Every quarter-day, your CRM will self-clean and surface your best opportunities automatically.
What to do next
  • Automate routing: Use the Lusha-calculated score to automatically route leads to the correct AE or SDR in HubSpot.
  • Personalize outreach: Use the enriched “Industry” or “Company Bio” fields to dynamically insert snippets into your email sequences.
  • Analyze the funnel: Compare the conversion rates of “fast-track” leads versus standard leads to refine your scoring logic over time.
The goal: Stop wasting your team’s time on unqualified data. This play ensures your CRM is a source of truth that proactively tells your reps who to call and why, powered by Lusha’s premium data.
