What it does: When any monitored workflow fails, Supervisor catches the error, classifies its severity, and sends a formatted Telegram alert — with the execution link, retry guidance, and circuit breaker status. It also runs a heartbeat monitor every 5 minutes and pings Healthchecks.io as a dead man’s switch.
Three safety layers: Telegram alert → cache if Telegram fails → Healthchecks catches silence if everything fails.
Workflow 2 — Heartbeat Monitor: Circuit breaker auto-recovery, error rate trends, Healthchecks.io ping, orphan execution detection via n8n API
Workflow 3 — Data Retention: Automated cleanup every 12 hours
The backstory: This is actually a rebuild. The original version (V23) was a 139-node, 8-workflow, AI-powered system that used DeepSeek to triage errors, search historical fixes, and suggest repairs. It was impressive engineering — and it cost ~500,000 tokens per error just to send a Telegram message that said “this workflow failed on this node with this error.”
The same information was already in the Error Trigger payload before any AI processing.
So I stripped it down to what actually mattered: catch the error, tell me, and make sure silence itself is an alarm.
The circuit breaker + deduplication combination in Workflow 1 is exactly the kind of thing that makes error monitoring actually usable in production - without deduplication you’d drown in duplicate alerts during a cascade failure. The rebuild from 139 nodes (AI-powered) to 46 nodes (zero AI) is also a good call, simpler systems are easier to trust when you’re debugging the monitoring system itself.
@perfectc
Wow, that’s really cool. I haven’t found another ready-made solution like this on the market. Did you ever think about using ping with a timestamp to not rely solely on the platform’s log?
Thanks! Yeah the dedup was born from real pain , one Postgres timeout would fire 4-5 identical alerts in seconds. You start ignoring them, and that defeats the whole point. And honestly the rebuild was humbling. Hard to justify 500K tokens when the Error Trigger payload already has everything you need. Plus you really don’t want to be debugging your debugging system.
Thank you! right now the heartbeat workflow pings Healthchecks.io every 5 minutes, so if n8n itself goes down or the workflow silently stops, Healthchecks catches the silence and alerts me. That’s basically the “ping with timestamp” idea but outsourced to a free external service. I did consider logging timestamps locally in Postgres as a backup, but figured if n8n is down, it can’t write to the DB either. So having an external service watching for silence felt more reliable. If Healthchecks stops hearing from me something is wrong, guaranteed.
Healthchecks catching the silence is a strong choice. A lot of n8n setups only catch thrown errors, so an external heartbeat is the right way to catch “nothing ran” failures.
The next thing I would pair with this is an issue lifecycle after the alert:
One deduped issue per failure window, not one alert per repeated failure.
Severity based on client/business impact, not just technical error type.
Owner and acknowledgement state.
Last good heartbeat, missed heartbeat window, and affected workflow/client.
Resolution note and whether a follow-up check passed.
That is the part many monitoring setups miss. The alert tells you something needs attention; the lifecycle tells you whether someone owned it, fixed it, and can explain it later.
Rory’s point about the issue lifecycle is the part that goes missing in most monitoring setups.
Detection and alerting are well covered here: the circuit breaker stops the flood, deduplication ensures you get one actionable notification per incident. The next thing that tends to slip is what happens after the alert fires.
Two steps help close the loop.
The first is acknowledgment tracking. When the alert lands in Slack, include a button (Slack Block Kit action with type: actions) that hits a webhook on click. The webhook writes: who acknowledged, at what time, from which workflow. This turns the broadcast into an assigned incident. Without it, three people might see the same alert, each assume one of the others handled it, and nobody does.
The second is recovery verification. After the workflow is fixed and restarted, a follow-up step polls the last N executions via n8n’s API (/api/v1/executions, filtered to that workflow id and status=success). If N=5 clean runs come back, it posts a “Verified: 5/5 healthy” message to the same Slack thread. If any fail, it re-escalates before you close the incident.
The reason this matters beyond the obvious: a lot of workflow failures come from bad input data rather than code errors. Fixing the code and restarting gets clean runs immediately, but if the bad data is still in the queue, it fails again on the next real event. Recovery verification with actual executions catches that gap before you declare victory.
The supervisor workflow in your setup is already structured to hold state across the detection phase. Extending it to hold incident lifecycle state is a natural next step.
