Automating ESP32 IoT sensor data workflows in n8n
Hi everyone, I’m exploring how to automate data flows from multiple ESP32‑based IoT sensors using n8n, and I’d love some guidance on best practices. For reference, I’ve been following this ESP32 motion‑detection project which sends sensor data via HTTP: https://www.theengineeringprojects.com/2022/03/iot-based-motion-detection-with-email-alert-using-esp32.html
I’ve seen Arduino forum threads and Raspberry Pi community projects where people push sensor updates via REST or MQTT, and even some discussions around bridging those streams into dashboards. In n8n, what nodes, triggers, or workflow designs work best for handling frequent small POST requests from multiple devices, while ensuring retries, rate‑limiting, and minimal latency?
Hey @Aria12 ! Welcome to n8n community!
I think that you would get in love with the Webhook Trigger node (and all the others!).
So:
Either have one webhook per workflow (e.g. per device type or per logical stream), or a single webhook that routes based on payload fields.
For high traffic, n8n recommends Queue mode with webhook processors:
Run multiple webhook processes behind a load balancer to scale intake of parallel requests…
So… yes, n8n fits very well with fetch/save/process/display data!
Cheers!
hi,
I had a MQTT server in the past and it was good at handling data from various devices (iot or not, in my case it was arduinos over rs232 or nrf24)
in your case, or if it was mine today, i would have a MQTT server running alongside n8n so that you communicate with it for viewing, reporting, or send commands via n8n, and the MQTT server handle the high frequency traffic of your IOTs.:slightly_smiling_face:
