Automation Architecture with n8n
Data Processing Layers in n8n organize workflows into clear stages so data moves logically from input to output.
1.First, the trigger layer collects incoming data from webhooks, schedules, or app integrations.
2.Next, the validation layer checks whether the data is complete, accurate, and usable.
3.After that, the transformation layer cleans, formats, or restructures the data for further processing.
4.Then the logic layer applies conditions, filters, or calculations to determine the correct action.
5.Finally, the action layer sends the processed data to external services, databases, or notifications.
nice to see architecture discussions here — doesn’t happen often enough. from running smb projects the biggest architecture question isn’t which nodes to use, it’s how you handle errors gracefully and how you prevent execution storms when trigger workflows fire uncontrollably. what surprised you most or cost you the most time when building this out?
