How much hardware is needed to have a certain amount of automations active? Is there a way to know how many workflows I can have active if I host n8n myself?
- n8n version:
- Database (default: SQLite):
- Operating system:
Self-hosting removes the limits to amount of workflows and executions.
You can have as many workflows and executions as your hardware and network can handle.
Documentation:
- Prerequisites | n8n Docs
- Scalling n8n | n8n Docs
- Performance and benchmarking | n8n Docs
- Configuring queue mode | n8n Docs
Here are some scenarios:
The bare minimum
I wouldn’t use less than this for any setup.
I’ve used 1 CPU and 1 GB of RAM before and it’s an ok experience, but it’s slow.
Minimal Load: Typically used for testing and low-frequency executions.
- Recommended Specs:
CPU: 1 vCPU
Memory: 2–4 GB RAM
Storage: 1 - 4 GB SSD (sufficient for logs and basic data)
Level 1 – Low Traffic Production
Ideal For: Small teams or low-frequency workflows.
- Specs:
CPU: 2 vCPUs
Memory: 4–8 GB RAM
Storage: 20–40 GB SSD
Provides enough headroom for moderate concurrent workflow executions without overspending.
Level 2 – Moderate Traffic Production
This is my current setup for managing small-to-medium marketing automations.
Ideal For: Growing operations with several concurrent workflows.
- Specs:
CPU: 4 vCPUs
Memory: 8–16 GB RAM
Storage: 40–80 GB SSD (preferably with faster I/O)
More robust resources to handle increased demand and prevent slowdowns during peaks.
Level 3 – High Traffic/Enterprise Production
Ideal For: High-volume, complex workflows with many concurrent executions.
- Specs:
CPU: 8+ vCPUs
Memory: 16+ GB RAM
Storage: 80+ GB SSD, with provisions for scaling storage as needed
Load balancing, separate database server, and redundancy setups. Ideally you should split the installation into MAIN
, WORKERs
and WEBHOOKs
This level ensures high reliability, performance, and the ability to handle scaling challenges.
If my reply answers your question, please remember to mark it as a solution.
