[Available for Hire] Senior Automation Engineer | n8n Expert | AI & System Architecture
Hi n8n Community,
I’m an Automation Engineer specializing in building robust, scalable, and logic-heavy workflows. My approach goes beyond simple integrations — I design end-to-end systems where n8n acts as a powerful backend engine for business logic.
Whether it’s fintech, data infrastructure, or custom AI pipelines, I focus on high-performance, self-hosted solutions that are modular, efficient, and easy to maintain.
:wrench: What I Bring
Infrastructure & DevOps
  • Deploying self-hosted n8n using Docker & Cloudflare Tunnels
  • Full control over data, security, and system reliability
Complex Workflow Engineering
  • Event-driven architecture
  • High-frequency automation systems
  • Rate-limit bypass strategies (proxy chaining, Tor, Docker setups)
Deep Technical Integration
  • Advanced use of JavaScript Function nodes
  • REST API integrations & custom Webhooks
  • Building logic beyond standard node limitations
Multi-Model AI Orchestration
  • OpenAI, Claude, Gemini, Ollama integration
  • AI pipelines for intelligent automation & decision-making
Financial & Data Systems
  • Algorithmic trading tools
  • Real-time tracking systems (WhatsApp, Google Sheets, custom DBs)
:gear: Selected Capabilities
  • Custom API Wrappers for non-native services
  • Performance tuning for faster execution & lower overhead
  • Scalable architecture for high-volume workflows
  • Local AI setup for cost-efficient processing
:handshake: How We Can Work Together
  • End-to-end automation system design
  • Fixing or optimizing complex workflows
  • Long-term infrastructure & automation maintenance
:envelope_with_arrow: Contact
Email: iqbalganz922@gmail.com
Let’s turn your manual bottlenecks into high-efficiency automated systems.
Best regards,
Iqbal Roofi
