AWS Lambda 5 mins timeout issue
Hello everyone,
I’m running into an issue with the AWS Lambda node in n8n and hoping someone can help or share advice.
It seems like the Lambda node in n8n has a built-in timeout of 5 minutes, regardless of the timeout settings configured in AWS for the Lambda function itself. My current Lambda function needs to run for longer than 5 minutes because it waits for other APIs to respond inside the Lambda. When I trigger the function from the AWS console, everything works fine and the function completes successfully, even if it takes longer than 5 minutes.
However, when I run the same Lambda from an n8n workflow, I consistently get a timeout error after 5 minutes.
Problem in node ‘AWS Lambda‘
The connection was aborted, perhaps the server is offline
“errorMessage”: “The connection was aborted, perhaps the server is offline”,
“errorDetails”: {
“rawErrorMessage”: [
“timeout of 300000ms exceeded”,
“httpCode”: “ECONNABORTED”
“n8nDetails”: {
“nodeName”: “AWS Lambda”,
“nodeType”: “n8n-nodes-base.awsLambda”,
“nodeVersion”: 1,
“operation”: “invoke”,
“time”: “9/22/2025, 12:47:54 PM”,
“n8nVersion”: “1.111.0 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“NodeApiError: The connection was aborted, perhaps the server is offline”,
" at ExecuteContext.requestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/node-execution-context/utils/request-helper-functions.ts:1472:10)“,
" at ExecuteContext.requestWithAuthentication (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/node-execution-context/utils/request-helper-functions.ts:1758:11)”,
" at ExecuteContext.awsApiRequest (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Aws/GenericFunctions.ts:35:10)“,
" at ExecuteContext.awsApiRequestREST (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Aws/GenericFunctions.ts:49:19)”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@[email protected]_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Aws/AwsLambda.node.ts:178:26)“,
" at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1254:8)”,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1428:11)“,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1760:27”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@[email protected]_@[email protected]_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2337:11"
  • n8n version: 1.111.0
  • Database (default: SQLite): PostgreSQL
  • n8n EXECUTIONS_PROCESS setting (default: own, main): Not explicitly configured (defaults to “main”
  • Operating system: Linux
Hi @pete.praewpun,
If there is a limitation with Lambda node, can you try using the HTTP node, which has a timeout option that you can adjust?
If that works, then the problem is indeed with the Lambda node limitation..
Hi @mohamed3nan , thanks for sharing this! I created the Lambda URL with a 7-minute runtime and extended the timeout option in Http request node to 7.5 minutes, and it worked perfectly. This confirms that the limitation is due to the Lambda Node doesn’t has option to configure Timeout.
You’re welcome @pete.praewpun
Kindly mark my reply as the solution, Have a great day, and hopefully the Lambda node gets some updates soon!
