Assuming you have the storage volume setup you should be ok but just incase you can use the cli tool to export the credentials CLI commands for n8n | Docs
Normally I don’t believe in backups but with some workflows it takes a while to get them just right, if you look at the templates there are a few for backups to places like GitHub which could help.
