Basecamp Oauth2Connection Keeps Dropping
Hi,
I have built a connection with Basecamp which works great but my issue is that the connection keeps dropping (although it will say connected every time I check our credential). I have to manually reconnect each time. Is there a way for us to automatically connect this please?
I am a beginner in n8n so any assistance would be great!
Thank you.
Please share how you setup the connection and credentials, otherwise it’s a guessing game :slight_smile:
I assume you’re using the HTTP Node and Generic credentials feature with OAuth2 API?
If you want to paste your workflow or a node, copy it from your canvas and use the </> button when pasting in your post.
