It appears that there is an issue with the baserow node. Using both a baserow self-hosted and cloud account, it’s not able to list tables. I have attempted this using my own self-hosted N8N and the N8N macOS desktop app with the same results. I have existing workflows that use baserow that appear to continue working fine, although if I edit the baserow node in any of them, the table turns red as it’s not able to generate the list of tables. The last update I can see to baserow was earlier this month, but I’m not sure if it’s related to that change as I haven’t setup a new baserow node in at least a month.
Sorry, forgot to check Github first. I see this was fixed yesterday. Will update shortly.
