Hey everyone,
I’m hosting my n8n instance on Elestio, and it’s been working flawlessly—until today.
I’m running a workflow that checks if a company has an spf.protection.outlook.com MX record. That part works just fine.
The issue arises with the Baserow node (which I also self-host). Here’s what’s happening:
I initially scraped data into a table named “XYZ 2011 - 2025”. Now I want to scrape into a different table: “XYZ 2000 - 2011”.
However, when I run the workflow, the execution still shows it’s writing to the old table (“XYZ 2011 - 2025”), even though I updated the node configuration.
Here are some screenshots for reference:
I’m going to restart the instance now, but I have no idea why this is happening.
Has anyone experienced something similar or have any ideas?
The ID doesn’t work manually, but I tried everything.
Thanks!
P.S. the RabbitMQ is connected to merger, the “clean up” function just messed it up visually.
