Basic LLM Chain cannot be used to generate audio using gemini tts model
I’m trying to send text to the models/gemini-2.5-pro-preview-tts model using the Basic LLM Chain node in n8n, connected to the Google Gemini Chat Model.
There’s no way to configure the required responseModalities parameter, which results in failure.
[GoogleGenerativeAI Error]: Error fetching from https://generativelanguage.googleapis.com/v1beta/models/gemini-2.5-pro-preview-tts:generateContent: [400 Bad Request] The requested combination of response modalities is not supported by the model. models/gemini-2.5-pro-preview-tts accepts the following combination of response modalities: * AUDIO
  • n8n version: 1.93.0
  • n8n EXECUTIONS_PROCESS setting (default: own, main): how i know?
  • Operating system: Ubuntu 24.04.2 LTS
I’m pretty sure an update needs to be done to make this work with n8n. I haven’t found any information if the gemini tts models work with rest api. Even the official documentation on github just includes how to setup the SDK.
