Hi!
n8n looks cool! I created successfully ClickUp Oauth2 credentials, but in the ClickUp node, I cannot select it from the dropdown. The same thing happens with the Slack Oauth2 credentials. With token-based authentication both works.
Should I be able to use the OAuth2 credentials in the node, for instance, to get a list of tasks from ClickUp?
To select your OAuth2 credentials, you need to click on ‘OAuth2’ from the dropdown list for the Authentication field. You should then be able to access the credentials that you created before. Hope that helps!
