Running latest version ona npm hosted on hostinger
Hi - I am a beginner and starting a first project to learn. I am currently stuck and need help to fix.
I have a Gmail Trigger to get scan I have sent to me. I get the attached file, send it to Atheopic to determine what is best file title and then I want to upload in a Dropbox folder .
Up to Anthropic folder I am good, but I am unable to upload the file using Dropbox Upload node. Binary file has been lost after Anthropic node.
Hi - I have copy/paste in a fresh new n8n Workflow. Links between “Extract Attachments”, “Analyze document”, and “Merge Filename with Binary Data” nodes are not being pasted correctly. I have tried replacating yours but Code node does not allow it. Shoudl I sue a Code node ?
@csimonnet thats cos the merge file name with binary data node is not receiving the binary data from the extract attachments node.
// This node merges the AI-generated filename with the original binary data
const aiOutput = $input.all()[0]; // AI response (from Analyze document)
const originalData = $input.all()[1]; // Should be from Extract Attachments
// DEBUG: Check what we're actually receiving
console.log('AI Output:', JSON.stringify(aiOutput.json, null, 2));
console.log('Original Data:', JSON.stringify(originalData, null, 2));
// Get the suggested filename from Anthropic
let suggestedFilename = aiOutput.json.text || aiOutput.json.response || 'document';
// Clean the filename
suggestedFilename = suggestedFilename
.replace(/\.[^\.]+$/, '')
.replace(/[^a-zA-Z0-9\s_-]/g, '')
.trim()
.replace(/\s+/g, '_')
.toLowerCase();
// Handle the binary data - it might be in different locations
let binaryData = null;
let originalFileName = 'unknown';
if (originalData.binary) {
// Data comes from direct binary connection
binaryData = originalData.binary;
const binaryKey = Object.keys(binaryData)[0];
originalFileName = binaryData[binaryKey].fileName || 'unknown';
} else if (originalData.json && originalData.json.originalData) {
// Data comes through JSON (fallback)
// You might need to reconstruct binary data here
// Get original file extension
let fileExtension = '.pdf';
const extensionMatch = originalFileName.match(/\.([^.]+)$/);
if (extensionMatch) {
fileExtension = '.' + extensionMatch[1];
// Combine suggested filename with original extension
const finalFilename = suggestedFilename + fileExtension;
// If we don't have binary data, try to get it from the original source
if (!binaryData) {
const extractNodeData = $('Extract Attachments').item();
if (extractNodeData && extractNodeData.binary) {
binaryData = extractNodeData.binary;
if (!binaryData) {
throw new Error('No binary data found for file upload');
return [{
json: {
suggestedFilename: suggestedFilename,
finalFilename: finalFilename,
originalFilename: originalFileName
binary: binaryData
