Beginner’s Tutorial: Automate Azure Blob Storage with n8n & OpenAI
In this hands-on tutorial, you’ll learn how to create a complete automation workflow using n8n, OpenAI, and Azure Blob Storage — all without writing any code!
Whether you’re managing AI-generated images or exploring Azure services for the first time, this guide will walk you through each step.
What You’ll Learn
By the end of this tutorial, you’ll be able to:
Manually trigger workflows in n8n
Generate image prompts using OpenAI ChatGPT
Create Azure Blob Storage containers dynamically
Upload, list, and delete blobs from Azure storage
Customize the flow visually in the n8n editor — no programming needed!
Tools & Technologies Used
n8n (self-hosted automation platform)
OpenAI API (ChatGPT & DALL·E)
Azure Blob Storage (authenticated via Access Key)
Who This Tutorial Is For
This tutorial is perfect for:
Azure beginners learning how to interact with Blob Storage -
Creators & makers using OpenAI DALL·E for image generation -
DevOps engineers & no-code builders looking to automate cloud workflows with n8n
Let’s get started and build your first AI + Azure automation workflow with n8n!
