Best way to integrate OpenAI model with large dataset
Hi fellow n8ners!
I am looking for some guidance from fellow n8n experts here.
How would you handle a workflow where you must feed 10K rows into the openAI node and have it output the results back into the google sheet? I tried connecting a rowAdded trigger to a loop through batch node (500 batch size) and then contain the OpenAI model within. Every time I try to test the openAI node the inputs disappear and results in no output. When I execute the inputs within the node they come back but as soon as I test the overall step again they disappear.
Is my overall approach not the best?
n8n version: 1.75.2
Database: SQLite
n8n EXECUTIONS_PROCESS: own, main
Running n8n: n8n cloud
Operating System: macOS Big Sur Version 11.7.10
