Best way to show images in a custom node
I’ve been working on showing an image in a custom declarative node.
I found the fileType field in the binary data returned, and no clear documentation on how to do complex declarative nodes, such as how to show a binary data for instance.
Is there a more complete “how to build your own node” documentation that docs.n8n.io? Is this routing.output.postReceive the best way to show an image, or is there another way that would be totally different? (I have multiple HTTP requests in my node and only one that returns an image, so I don’t want to do a run function just for one endpoint.)
    postReceive: [async (items): Promise<INodeExecutionData[]> => {
        let bufferData = Buffer.from(items[0].json as unknown as ArrayBuffer);
        const base64Data = bufferData.toString('base64');
        return [{
            binary: {
                data: {
                    data: base64Data,
                    mimeType: 'image/png',
                    fileSize: bufferData.length.toString(),
                    fileType: 'image'
            json: {},
(the most basic one, I don’t think it matters)
The output is what I want, my question is more about implementation.
  • n8n version: 1.80
  • Database (default: SQLite): default I think
  • n8n EXECUTIONS_PROCESS setting (default: own, main): default I think
  • Operating system: ubuntu 24.04
I had the same issue as you before and it seems you can’t do that with declarative nodes. So I ended up converting it into programmatic node in order to receive my image correctly.
To get an idea you check have a look at my code on github:
