Hi n8n team,
I discovered your tool 1 week ago, and after an installation on a Debian VM hosted by Google Cloud (I never used linux before), i’m starting to play with nodes !
I used Google BigQuery as datawarehouse and I want to create a new table.
The BigQuery node cannot do it so i’m using HTTP nodes with Oauth2 auth.
When I’m using a POST request to create a new table I’ve the following issue
ERROR: UNKNOWN ERROR - check the detailed error for more information
Request failed with status code 400
NodeApiError: UNKNOWN ERROR - check the detailed error for more information
at Object.execute (/usr/lib/node_modules/n8n/node_modules/n8n-nodes-base/nodes/HttpRequest/V3/HttpRequestV3.node.ts:1313:12)
at processTicksAndRejections (node:internal/process/task_queues:95:5)
at Workflow.runNode (/usr/lib/node_modules/n8n/node_modules/n8n-workflow/src/Workflow.ts:1261:19)
at /usr/lib/node_modules/n8n/node_modules/n8n-core/src/WorkflowExecute.ts:949:29
I copied the Curl request from Google API Explorer and just change the credential (in order to limit body issues)
When I try a GET through http request node it’s OK no error.
I tried to log issue through n8n log file but I do not have more information.
For now, I don’t use transformation.
- n8n version: 0.222.2
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): npm
- Operating system: debian-11-bullseye-v20221206
Thank you in advance for your help
