Binary file problem
Hi, I’m having trouble with a loop that doesn’t clear one of the transition branches. The problem is that after processing an erroneous element and returning to the loop, in the next (correct) iteration, the Merge and HTTP Request nodes on the IF True path don’t reset the context and accidentally merge the binary file data from the previous, erroneously processed element. How can I sensibly solve this problem if the upload must be performed if the document analysis is correct, and the binary file must be there first?
hello @Misi11
Please, share the workflow.
You can select all nodes with Ctrl+A and copy them with Ctrl+C. Then, past the content after pressing the button </> with Ctrl+V.
Hello, barn4k, cannot paste workflow
