I’m using the community node above and I appreciate it! I was hoping to post images but haven’t quite figured out how to do so.
There is an open request here
That mentions a fork that supports images.
It would be ideal to merge that into the original node by @cmuench
I needed this for a project. I forked the community node and added some missing features.
Wow, incredible upgrade.
Might consider creating a PR to the original node so people who has been using it don’t need to change all their nodes?
Thanks for the great work!
Hi Brian, thank you for the bluesky-enhanced node. I really appreciate the work that you’ve put into improving n8n’s functionality with Bluesky. It makes it a lot easier for me to post to the platform without having to mess around with HTTP requests.
One issue I’ve noticed is that if I am trying to create a post with the Fetch Open Graphs setting and it fails to correctly populate the open graph data from a website, the node returns an error and doesn’t post anything to Bluesky. I would love to be able to set a fallback option. Even just posting the link as a link would be amazing. I can send more details by DM.
