[Bug] different locale when using .weekdayLong in expression in preview and output
The preview shows german word for weekday, the output is english.
Locale is Europe/Berlin.
  • n8n version: current
  • Operating system: ubuntu
Hi there,
Are you sure the locale of the server is set right? can you show us?
As the default is newyork or somehting like that, so an execution would use that but the preview is done by the browser so that is done with your browser’s locale settings. (most likely the same as ur pc)
the timezone in n8n is set Europe/Berlin
locale of the Ubuntu server is set to de_DE
grafik
the docker container I’m unsure.
which one of these is used for the preview vs. the actual results idk.
Ok then you need to set the ENV variable of the n8n container to the correct locale :slight_smile:
You can also set the locale directly in the node with Luxon
{{ DateTime.fromISO($json.Zeit.start).setLocale("DE").toFormat("EEEE") }}
setting the
N8N_DEFAULT_LOCALE to ‘de’ or ‘de-DE’
doesn’t affect the output as shown below.
Not sure what ENV variable to set exactly I think there were 2.
Should be some more topics on that on the forum though.
