Hello n8n team,
I’ve been stuck for two days trying to perform a very simple mathematical filter, and the Filter Node seems to be failing to convert types properly.
My workflow:
I am pulling videos from the YouTube API. The YouTube API returns the viewCount inside statistics as a String (e.g., “485655”).
I am trying to filter out videos that have more than 15,000 views using the Filter Node.
My Filter Node configuration:
Condition: Number
Value 1 (Expression): {{ $json.statistics.viewCount }}
Operator: # is greater than
Value 2 (Fixed): 15000
Convert types where required: TRUE (Toggle is ON)
The Issue:
Even with the “Convert types where required” toggle turned ON, the node crashes and throws the following error:
Wrong type: ‘485655’ is a string but was expecting a number [condition 0, item 0]
I have also tried using Number(), parseInt(), and .toNumber() directly inside the expression, but the node either throws a syntax error or fails to evaluate the condition correctly, moving all items to the “Discarded” branch.
Is there a known bug with the strict type-checking in the current version of the Filter node? Any help or workaround would be greatly appreciated.
Thanks,
Andrés
The node throws this specific error: Wrong type: '485655' is a string but was expecting a number [condition 0, item 0]
The YouTube API returns the view count as a string inside the JSON:{
“statistics”: {
“viewCount”: “485655”,
“likeCount”: “15372”,
“favoriteCount”: “0”,
“commentCount”: “1074”
- n8n version: Cloud (Latest)
- Database (default: SQLite): Default
- n8n EXECUTIONS_PROCESS setting: Default
- Running n8n via: n8n Cloud
- Operating system: Windows 11
